Old 12-22-2020, 07:37 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default cylinder wall finish
i have a sbc block that was honed years ago...have used different clensers to wipe/clean the walls down, leaving some resadue....will it affect ring seal? tks.
Old 12-22-2020, 07:53 AM   #2
SGSST109E
Liked 126 Times in 61 Posts
Default Re: cylinder wall finish
Auto trans fluid on a rag. Clean until it doesn't show any trace. If its rust you need to hone.
SGSST109E is offline   Reply With Quote
Old 12-22-2020, 08:15 AM   #3
richie 2
no rust...just stains from the cleaners...dull, not a shinny surface.
Old 12-22-2020, 01:18 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
If in doubt hone it.
Old 12-22-2020, 07:48 PM   #5
Frank Castros
Liked 2,741 Times in 967 Posts
Ask yourself, why would I take a chance with ring seal? A light hone to “clean” the finish is what I recommend.
Old 12-23-2020, 08:25 AM   #6
richie 2
will do tks guys...
Old 12-23-2020, 01:13 PM   #7
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I have the same issue with a block I had to the machine shop, sat around in my garage for too many years. Now I have a little time, pulled it off the shelf and the WD-40 I sprayed on it to keep it from rusting dried on the cylinder walls. Recleaned it, and didn't like the look of the cylinders.Started checking clearences, and the piston to cylinder wall measurement isn't to my specs. So I am going so send it out to get rehoned again.
Patric Fox is offline   Reply With Quote
Old 12-23-2020, 05:36 PM   #8
SSDiv6
Liked 1,604 Times in 583 Posts
The over the counter WD-40 is a water dispersant and was not designed for long term corrosion protection.
However, in the WD-40 product line, they do have a WD-40 industrial product by the name of WD-40 Specialists Rust Inhibitor Lubricant that is for long term corrosion protection.
https://www.zoro.com/wd-40-specialis...35/i/G4477243/
Another great corrosion inhibitor is Hornaday One-Shot lubricant. Although it was designed for guns, it is a great long term corrosion protectant for metals.
https://www.cabelas.com/shop/en/horn...shot-case-lube
Old 12-23-2020, 05:38 PM   #9
Mike Miljanovic
Mike Miljanovic's Avatar
Liked 6 Times in 6 Posts
Watch, watch, watch: WD 40 is the worst thing for rust prevention. I bought a block that was stored for five years; was told it was sprayed once a year. Machinist gave it back to me & said .030 over will not clean it up; looking for another block. Lost a crank that same way. Grease it up boys; lasts forever!
Mike Miljanovic is offline   Reply With Quote
Old 12-23-2020, 06:34 PM   #10
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
also heard kroil in the orange can works good?
427FE is offline   Reply With Quote
