Old 12-16-2020, 07:54 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default street/strip engine question
hope you's dont mind me in this section. very healthy 496ci/auto, 67 chevelle. holley hp 950 carb. need to determine lean/rich conditions with 8'' of vacume @ idle. egt probes/system in the headers? tks a bunch for any suggestions.
Old 12-16-2020, 07:58 AM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: street/strip engine question
Originally Posted by richie 2 View Post
hope you's dont mind me in this section. very healthy 496ci/auto, 67 chevelle. need to determine lean/rich conditions with 8'' of vacume @ idle. egt probe/system in the headers? tks a bunch for any suggestions.
Put an O2 sensor and data logger in it.
Old 12-16-2020, 08:01 AM   #3
richie 2
tks glen, who makes that system?
Old 12-16-2020, 09:08 AM   #4
jmcarter
jmcarter's Avatar
Call him, you won’t be sorry...
http://www.motorsportsinnovations.com/
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-16-2020, 11:08 AM   #5
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Here is another option for an monitoring air /fuel ratio:
http://www.daytona-sensors.com/wego-...-displays.html
easy to install and has many options
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 12-16-2020, 06:23 PM   #6
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Ive used an Autometer wideband gauge and O2 sensor in my truck to get a tune out of it. Works great.
Dave Noll, EF/S ,?/SA 6526
Old 12-19-2020, 05:29 PM   #7
monte385
Liked 27 Times in 19 Posts
With an idle with 8" vac. it must be fairly lumpy, so the wide band won't be very accurate at idle but will be useful above that,
monte385 is offline   Reply With Quote
Old 12-19-2020, 06:13 PM   #8
richie 2
@ idle is the issue. way rich. have been all through the tuning to no avail.
Old 12-20-2020, 10:58 AM   #9
Bob F
Liked 16 Times in 11 Posts
What have you tried?
Bob F is offline   Reply With Quote
Old 12-20-2020, 11:30 AM   #10
L.Fite
Liked 497 Times in 243 Posts
Does that carb have the holes in the butterflies?
On Dominators I've had success with restricting the idle feed holes.
L.Fite is offline   Reply With Quote
