#1 | |
Had a neighbor complain at one time that he had the lube on his stick shift car changed and they had damaged his transmission because it was difficult to shift. Had him show me the invoice and they had put 90W140 gear lube. Asked him for his owner's manual and it showed it required ATF. Told him to go back to the shop and have them replace the oil with ATF. He came back and said the problem was gone. Told him he and the shop were Morons; him for not looking at the manual and the shop for not knowing what they were doing, especially with a kid working at minimum wage. |
Liked 22 Times in 14 Posts
ATF
Liked 134 Times in 28 Posts
I have never found any rear end gear lube that performed "better" when doing the late race hot laps and for wear protection then Mobil1, 75W90 full synthetic.
I use the same in my RWD vehicles. I used to go through at least one gear set every season; now I still run the same 9" ford Pro Gears that I ran 20 years ago. Ask the rear end set up guys in NASCAR. |
Liked 20 Times in 15 Posts
just remember, for U guys who are running posi/trac-loks or whatever [any thing besides a spool], do NOT use synthetic lubes. same goes for brass syncro transmissions.
Rod in AZ |
Liked 117 Times in 50 Posts
I ran ATF in the rear end of my Mazda...
My 12 Bolts have done great running Torco 85-140 with pro gears, backlash clearance makes a difference with the viscosity lubes you use also. Synthetic is more slippery and somewhat thinner than mineral based lubes, tight clearances can benefit from synthetics.
