Old 12-14-2020, 06:58 PM   #1
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Rear end Gear lube
What brand and wieght do you use.
Did a quick search and didn't see any previous
post
Stocker
Not that it matters but 12 bolt spool lighten pro gear
Thanks. David
Willyracer is offline   Reply With Quote
Old 12-14-2020, 07:20 PM   #2
SSDiv6
Default Re: Rear end Gear lube
post
Stocker
Thanks. David
Synthetic - Amsoil Severe Gear 75W90
or
Conventional - Torco RGO 85W140
Old 12-15-2020, 04:18 AM   #3
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Redline Superlight Shock Proof
Dave Noll, EF/S ,?/SA 6526
Old 12-15-2020, 08:23 AM   #4
Billy Nees
Liked 7,783 Times in 1,743 Posts
Laugh if you want to but I've used Dexron for years.
Billy Nees 1188 STK, SS
Old 12-15-2020, 08:31 AM   #5
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
We run 75-90 Amsoil synthetic, but this is interesting .....
https://www.currieenterprises.com/wh...ional-gear-oil
Jeff Niceswanger 3740 SS
Old 12-15-2020, 10:42 AM   #6
Rory McNeil
On my stickshift cars, I like the Redline Heavy Shockproof gear oil. Use the same or Medium Shockproof in my Jerico and G Force 4 speeds too.
NHRA 6390 STK
M/S 85 Mustang
Old 12-15-2020, 11:53 AM   #7
Lee Valentine
Liked 319 Times in 68 Posts
What Billy said.
Lee Valentine 1661 STK
Old 12-15-2020, 12:33 PM   #8
FED 387
Liked 333 Times in 180 Posts
for a stocker whatever is on sale ---just as long as its lightweight---change it out yearly unless you change rear differential--change gears or pull it out to check it --JUST DONT MIX DIFFERENT VISCOSITIES !!!!--FED 387
Old 12-15-2020, 05:09 PM   #9
SSDiv6
Jeff,
The Currie Oil is actually rebottled Torco.
Torco Mineral Oil is what Mark Williams recommends.
Old 12-15-2020, 05:12 PM   #10
SSDiv6
...and probably recycled too!
