Old 12-08-2020, 02:51 AM   #1
GTX JOHN
Liked 2,486 Times in 697 Posts
Default Re: CTS trailer problem
Ray Charles coulda seen that coming.
That is NOT the way to attach a tongue to a trailer frame.
You need to run a wrap around tongue going back to front axle hanger even
on a 7000 steel open trailer!! (WE have built trailers for 30+ years}.
Especially on a Aluminum trailer!
They are fragile enough if under rough treatment!
Unbelievable!!!!
John Irving
741 Stock
741 Super Stock
Old 12-08-2020, 08:18 AM   #2
Liked 10,747 Times in 2,235 Posts
Just for fun show those pictures to the local trades school instructor. His opinion will give you something to talk about if it leads a legal discussion.
Old 12-08-2020, 08:44 AM   #3
Ralph A Powell
Liked 225 Times in 136 Posts
Had the same type problem on a Featherlite 15 years ago it cracked were the tounge was welded to main rails right along the weld the cracked across the floor trailer dam near cracked in half. I was at the IRL RACE in Phoenix. They had their service team there but didn’t have a big enough welder so they called one in and patched it up enough to get it back to their factory in Iowa were they completely rebuilt the front section. I had bought a new one and was setting at home in my shop. When I got home we jacked it up and it was welded the same way. Featherlite sent someone to get it took it back to factory in Iowa and completely redone the tounge to frame welding and reinforcement and returned it back to my shop. The problem was when they welded it the first time it caused a stress riser right along the frame were the weld was.
Old 12-08-2020, 11:02 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Not only a bad design also some really bad looking welds.
Mike Pearson 2485 SS
Old 12-08-2020, 11:23 AM   #5
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Must be a lot of that going on. I saw an ATC (24ft ?) on I-85, just south of Charlotte, in the middle of the highway, missing the tongue. It was hanging off the back of a duality, on the shoulder 100 ft away, a few weeks ago.
2894 STK
Old 12-08-2020, 11:56 AM   #6
SSDiv6
Not enough weld penetration and this type of joint needs to be reinforced.
Those welds may be good for a living room table, but not for a high load structural joint.
Find a certified welding inspector and pay them a few bucks for a letter. Then have a lawyer send them a letter and attach the report with a statement that you will be also filing a report with the National Highway Traffic Safety Administration (NHTSA) for the defective welds and request a recall.
I promise you they will either fix it properly or give you a new trailer. They would not like to have the NHTSA pay them a visit, shut them down and fine them.
Old 12-08-2020, 12:12 PM   #7
SSDiv6
Also, if you can, find out what type of Aluminum alloy they are using in the construction of the trailer. 2024 and 7075 Aluminum should never be welded. The heat from the welding process will cause severe cracking.
Old 12-08-2020, 02:39 PM   #8
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Thanks for the suggestion I didn't think about
getting someone like NHTSA involved
Willyracer is online now   Reply With Quote
