#11 | |
NHRA Tech needs to correct their interpretation of a heim end and spherical bearing. A heim end is not a spherical bearing; the heim end contains a spherical bearing and all heim ends are threaded and adjustable. The Global West bars are identical in form and fit and function as the OEM bars and not adjustable. The only difference is it has a solid bushing at one end and a spherical bearing contained at the other end. Since needle bearings in lieu of bushings are allowed as a replacement to front lower and upper control arms, what is the difference? |
#12 |
Liked 223 Times in 73 Posts
I agree with SSdiv6 about what a Heim joint and a spherical bearing is. I did ask this question to NHRA about what a heim joint was? Heim joints are an adjustable threaded rod end. I should have gotten this in an email, but this was just an open question at that time. Have learned from my mistakes and get my question answered in emails for future discussion. My next question has to do with what is written in the rule book, a rear trailing arm my be replace with an NHRA accepted OEM type aftermarket unit. Under NHRA accepted products there is nothing list for suspension parts. So if you want to use one of these products you need to get a letter from NHRA saying it is accepted. Would be nice if they maintained a list of what has been accepted.
Is there anyone out there that has a letter from NHRA on rear control arms that has been accepted. And what is there application.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 Last edited by west coast; 11-03-2020 at 07:09 AM. |
#13 |
Liked 140 Times in 51 Posts
If you want to keep the stock bars,HRPARTS offer a Delrin bushing and it seems to work very well. Best of luck.
The more people I meet the more I like my dog Kevin |
#14 | |
Liked 72 Times in 36 Posts
Kenney Kelley . |
#15 | |
#16 |
Liked 28 Times in 15 Posts
I have pressed bushings into two sets of rc arms.
