Old 10-31-2020, 05:40 PM   #5
jamie2370
Liked 239 Times in 90 Posts
Default Re: 200 metric issue
I did not measure anything before I unstacked it. Assumed with steel in the pan it was gonna be bad. Anchor pin is good. Going with a Sepanek manual valve body. Its going to my trans guy now. Next question. Should you have to put 3 washers(stacked together) between the converter and flexplate? Thats how it was when I got it. I'm guessing mabye 1/8" worth of shim. I feel it is really close to being bottomed out in pump.
jamie2370 is offline   Reply With Quote
