Sponsor
Liked 714 Times in 120 Posts
I just pulled up a HP Tuners file for that engine combination and body. the speed limiter is active at 106 MPH and turns back on at 104.
very basic ECU and should be very easy for you to come up to speed. Most notable the Torque table limits in 4 gear. There are no COT or Cat Over Temp in this ECU. Your rev limiter as 6500. Could be a little in the shift scheduling also. I have my own chassis dyno that I do some work on the side so I play with some of the late model flash ware like the HP Tuners. Great project! Good luck. Robin
STK 308 SS 3088 |
