Old 10-25-2020, 10:07 AM   #14
james schaechter
Default Re: Damn...305 superstock engine receives 15 hp.....
Originally Posted by thomas sheehan View Post
Not true James... this only goes one way. (SS car goes fast- hit GT hp too)
3800 lb big air grabbing chevelle (or worse- some big wagon) running SS. Racer takes that motor combo and puts in GT car (cavalier?). Definite advantage for the more aerodynamic cavalier.
Thus, GT cars were given a separate HP from SS cars. If a GT car goes fast, it should not effect the SS cars (only SS cars going fast should hit both HP'er)
GT HP should NEVER have hp lower than the SS same combo.
But you are right about one thing.. NHRA probably won't change it... BUT they should.
I agree to start it shouldn’t. I guess I was considering that GT already had some et penalty built in as well. Maybe not alll, but the ones that I look at. For example. If you look at the 9-9.5 lb weight breaks for SS and GT, the index for SS is .15-.2 slower than GT.
I think the same consideration for combining stick and auto classes can be made. For some, but not all classes. In my view, their are several classes like GTF-GTH,that could be combined. The hp is much higher in automatics for these classes because the indexes were too slow to begin with. Most of the good automatic stuff with Radials can run with a stickshift.
I know this doesn’t apply to all combos but if NHRA wanted more heads up races, they could do this with at least some classes.
James Schaechter 3163 STK
