Liked 272 Times in 108 Posts
Yes or no?
Fast 36lb bosch style injectors $305 for (8) E bay 36lb bosch style injectors $52 for (8) |
I have had great service from my FAST injectors. Had them flow tested “on the bench” before installing them. All 8 tested right on. I can not imagine buying 8 injectors for 52 dollars?
Ed Wright 4156 SS/JA |
No luck with the cheap stuff on our Ram Diesels!
Liked 275 Times in 76 Posts
You get what you pay for, how much is your engine worth?
Sponsor
Liked 716 Times in 120 Posts
I would stay away from the E Bay injectors. I have heard horror stories about sticking open, sticking closed and flow variances in excess of 10%.
I flow all of my injectors to ensure they are within range. Robin
STK 308 SS 3088 |
Liked 140 Times in 46 Posts
I tried a set of Ebay injectors and I should have just thrown my money out the window on the way down the track. I purchased 2 sets of AFIS injectors and they are amazing! They aren't cheap but you get what you pay for and I'm supporting a localish business in Ohio.
Jon Sarrett Stock 3779 |
#7 | |
Liked 734 Times in 385 Posts
Robin, Do you use n-Heptane or something else? Just curious. Stan |
#8 | |
Sponsor
I know at Holley they flow the carbs with Mineral Spirits. Robin
STK 308 SS 3088 |
#9 | |
Robin. Thanks. No matter what fluid is used you can tell if all injectors in a set will flow the same or not. But I am not sure how much the fluid used effects the flow rate so that injectors can be compared to injectors from another source. Stan |
Liked 269 Times in 99 Posts
