#101 |
You can buy a piston from any manufacture = Tell them it is for superstock or a bracket car maybe some other non stock eliminator use. Then lazer cut the NHRA approval on it yourself - Is that your violation and did you not mislead the manufacturer of your purpose?
#102 | |
Liked 1,596 Times in 583 Posts
I believe that could be the scenario. However, the question is if they would admit they did it or blame the piston manufacturer and give them a black eye? It is a can of worms! If it keeps happening, I can see NHRA allowing any ring package and doing away with something else to inspect. |
#103 |
Liked 140 Times in 46 Posts
The Duster incident happened last year at the Joilet points meet. He was the D3 rep in stock and could hardly run the index (post teardown) after going consistently .80-.90 under for years. I've been through many teardowns and NEVER lost 8 tenths or more.
Jon Sarrett Stock 3779 |
#104 | |
Liked 172 Times in 81 Posts
As far as my Pacer goes, if you want to see inside the engine I'll tear it apart just for you any time you want. Jim Mantle V/SA 6632 |
#105 | |
Liked 167 Times in 81 Posts
Tim Schmackpfeffer 762 SS |
#106 | |
Liked 5,129 Times in 1,956 Posts
If they go that route, then REAL replacement Stock pistons are at even more of a disadvantage. Another shot at the budget racer, and another rule revision rammed through by the cheaters. So then what happens? Under weight pistons and rods? Knife edged cranks? Where does it end?
#107 | |
I just pointed to a plausible aftermath with everything that has taken place in the past. |
#108 |
Tim,
Thin piston rings with spacers have been allowed for a long time. There are lots of piston ring designs that can achieve the same as the gas ported rings. At the end of the day, it is having the ring hone finish, a round bore and compatible rings that make the power. |
#109 |
Liked 56 Times in 33 Posts
Stock is ALMOST a S/S class now !
#110 |
Liked 2,966 Times in 713 Posts
Without tech and integrity of the racers Stock is long gone.
I have heard that if you build a stocker strictly by the rule book, you are behind the eight ball. I know there are some exceptions, but just sayin'. I don't fully understand but that's what I heard, a few years ago.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. Last edited by Carguy49; 10-17-2020 at 11:40 AM. |
