Old 09-30-2020, 06:01 PM   #1
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: 350/360/330 SBC with E-brock heads - CRICKETS
Here's the answer I got from multiple sources at NHRA Technical:
"If you show up with them on a Stocker, you'll be bounced because we know the ports are over the c.c. limit. If we check them and they come up correct, you'll be bounced because we know you've welded them."
I asked why they were still shown as a replacement head for Stock and only one person gave me an answer: "They shouldn't be."
Catch 22.....
"That'll never work....."
Old 10-01-2020, 07:01 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Catch 22.....
Well then I know of several stockers that have these heads (Non Chevy) and I know the heads were produced larger than stock. They were told, "by tech", they have to be X cc's so they did what they had to do to make them legal size. I don't believe NHRA will look properly at these heads in all divisions... Crazy.
Robert Simpson is offline   Reply With Quote
Old 10-01-2020, 10:04 AM   #3
nhramnl
Liked 358 Times in 83 Posts
Does anybody REALLY think that in these COVID times, there will ever be teardowns, as we all knew them? Hell, there isn't even tech inspection anymore. You write what you want your car to be on your tech card, and your wish is granted. I'm waiting for the first guy to show up with a big-block, claiming it's a 283.
Old 10-01-2020, 10:15 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 310 Times in 104 Posts
The 170 cc intake could be reduced enough for most small block stockers..
the 185 not so much
Old 10-01-2020, 11:03 AM   #5
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Can I get the number for the 170 heads. My heads are 168cc. Thanks
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 10-01-2020, 11:24 AM   #6
Alan Nyhus
Originally Posted by Mike Taylor 3601 View Post
The 170 cc intake could be reduced enough for most small block stockers..the 185 not so much
Mike, NHRA shows the Edelbrock heads as having 172 c.c. int. port volume and accordingly adds 5 h.p. to the factor if you use them.
However, as supplied by Edelbrock, they are 185 cc intake ports.
Old 10-01-2020, 11:32 AM   #7
Daran Summerton
172 is for SS. Stock is same as factory.
72 cutlass
Old 10-01-2020, 12:38 PM   #8
Bobby Lundholm
Liked 127 Times in 49 Posts
Dart is the same way. I ordered a set and they were 180cc. I called Dart and talked to their quality control and was told that the tooling has been worn making the runners larger than advertised. I do know if you find an original older set they do match up to NHRA's specs.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 10-02-2020, 02:59 PM   #9
Mike Taylor 3601
That's not good...
Old 10-01-2020, 11:14 AM   #10
james schaechter
They checked valve lift this year at one race. Throttle bodies. Not a piston pull, but some looks
James Schaechter 3163 STK
