Old 09-16-2020, 08:59 AM   #1
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Default Re: new swap firing order camshaft
Crickets ... ... ...
Old 09-16-2020, 11:12 AM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Some are doing the LS firing order. -Al
"That'll never work....."
Old 09-16-2020, 11:45 AM   #3
nhramnl
Liked 358 Times in 83 Posts
I just ordered a new camshaft for my car... NO firing order. Supposed to save HUGE money and time. Engine won't run, so you are forced to stop throwing endless money down a rat-hole, trying to have fun drag racing. Supposedly, other guys who have bought them have already adapted to the new configuration, and are sitting in lawn chairs, on their decks, drinking beer and sleeping in the sun. Can't wait...
Old 09-16-2020, 01:06 PM   #4
Tim H
Tim H's Avatar
And you can reuse your old lifters ... Ha ha
Old 09-16-2020, 01:25 PM   #5
SSDiv6
Liked 1,575 Times in 580 Posts
Only works on specific applications and will not work with carburetors and dual plane intake manifolds. The LS has the Ford firing order, however, they do not run a dual plane intake with a carburetor.
Old 09-16-2020, 01:34 PM   #6
GTX JOHN
Liked 2,470 Times in 696 Posts
We have tried single and double swaps on our old Mopars.......
No help that we can find in performance.
But it never fails to Confuse me when we R and R the Distributor or
Cap!
John Irving
741 Stock
741 Super Stock
Old 09-16-2020, 02:42 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
LS firing order. don't use with a dual plane intake.. Make sure the headers are correct, too. Might see a little HP if all is right, but will definitely see better main bearing life and possibly timing chain wear.
BTW: One of the stories on why Ford did it on some HO 302 and all 351 W's was to stop breaking cranks and have less front main wear.
Adger Smith (Former SS)
Old 09-16-2020, 02:50 PM   #8
J&S Racing
Liked 319 Times in 82 Posts
I recently had a 565 built by Schmidt, the father of the 7/4 swap. He put a cam with the LS firing order in it so I sat down with him and talked if it would benefit my stocker motor.
He basically said the 7/4 swap usually sees a small gain in HP but no big difference with the 4cyl swap. He said the advantage with the LS firing order is it drastically improves harmonics in the motor and is easier on the bearings.
Sitting in my rail the LS firing order definitely is a lot smother at idle.
More than likely I’ll have a cam ground with the LS firing order when it’s ready for its 1st rebuild.
J&S Racing is online now   Reply With Quote
