Old 09-11-2020, 10:56 AM   #1
Chuck Garey
Liked 10 Times in 7 Posts
Question 65 olds 4gc floats
Brother is looking for floats for 65 olds 4gc floats. Been told they are unique?
Carb.us tech said he's never seen them in 30 years
Chuck Garey is offline   Reply With Quote
Old 09-11-2020, 01:35 PM   #2
rocketman269v
rocketman269v's Avatar
Liked 4 Times in 4 Posts
Default Re: 65 olds 4gc floats
Try posting on this forum; '65 Olds 442 only. Good Luck.
https://w29.boards.net/board/4/65-442-wanted-sale
rocketman269v is offline   Reply With Quote
Old 09-11-2020, 07:21 PM   #3
scott gray
Liked 27 Times in 4 Posts
Are they unique in that they're tapered??
scott gray is offline   Reply With Quote
Old 09-13-2020, 12:12 PM   #4
rocketman269v
The true 442 4GC carbs had plugs in the front to facilitate jet changes without pulling the top.
Old 09-14-2020, 01:20 PM   #5
Chuck Garey
trying to get good pics i know they are phonolic floats kind of square
Old 09-14-2020, 09:49 PM   #6
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Chuck... Try these numbers 7028875 & 7012797. There is basically 3 style of floats that are somewhat common (for the vintage carburetor) that I have seen. "D" shape, Round, and Tapered Rectangle (kinda rare). There is Camelback or notched (rare). Were his originals foam or brass? On this side of the border, cores are tough to find and most times you can get away with used floats. Hope this may help...MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 09-15-2020, 09:13 AM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
The three types of 4GC floats. Top ones are the pontoon style, middle are the 'D' or 'rounded' style, bottom ones are the phenolic. Make sure you use the correct top gasket (cutout for the float or solid).
Hope this helps. -Al
"That'll never work....."
Old 09-14-2020, 09:13 PM   #8
Liked 5,125 Times in 1,953 Posts
The 65 409/340 were that way, also ;-)
Old 09-11-2020, 07:34 PM   #9
killintime6968
Liked 91 Times in 29 Posts
Did some digging through my old GM parts books and the primary floats are different. Also are different between the performance version and standard.in Olds applications
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 09-12-2020, 01:37 PM   #10
killintime6968
There was 2 versions of the 65 olds 4gc. The high performance 442 used different floats. Primary bowl float #7029794. I see one for sale on ebay. Not sure of the secondary float #. The low performance 4gc used different floats. My books at work don't show #
Bruce Cameron
68 Nova 396 E/S
