Old 08-14-2020, 01:00 PM   #1
Painter
Liked 162 Times in 45 Posts
Default Re: Wire Shielding EMI or RF Noise?
I think that I would completely eliminate the alternator first. Belt off, wires off and isolated make run and see what it does. Maybe install extra grounds. Start with one from ignition box chassis to known ground. And do t trust any grounds! Us the “tug test” on every connection ground and hot. Steel wool all terminals and where they connect.
Painter is offline   Reply With Quote
Old 08-14-2020, 09:01 PM   #2
SS3860
Liked 165 Times in 56 Posts
Electric fans are a good source for interference also. Separate all ignition wiring from fan wires.
SS3860 is offline   Reply With Quote
Old 08-14-2020, 09:12 PM   #3
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
Try a 10k ohm 1/2 watt resistor in tach wire
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 08-15-2020, 12:03 AM   #4
CMcAllister
Liked 920 Times in 259 Posts
I keep ignition wiring and "dirty" lines (alternator, fans & motors) separated as far apart as possible. And twist or braid the ignition trigger wires.
All grounds are connected to the ground post of the battery with copper - wires, cables. Don't rely on sheet metal.
Would be interesting to see what happens if the alternator is not functioning on a pass.
Old 08-15-2020, 12:12 AM   #5
FED 387
Liked 333 Times in 180 Posts
try grounding the head to the block and the block to the frame or body with the old style braided ground straps--NEVER use solid core wire for ground wire --if you do use braided wire make sure it is of sufficient gauge and not only crimped but put a bit of solder on the wire and connecter crimp area to make sure it is really grounded ---
Old 08-15-2020, 09:04 AM   #6
Painter
Solder is often confused as the very best in connections, when in fact poorly solder connections are very bad. If you don’t know how and have good equipment then stick with good crimps and vigorously apply the “tug test”!
Old 08-15-2020, 03:24 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Too many devices on a common ground can lead to r/f noise .
As was mentioned the fan is the single dirtiest source on the car followed by the electric fuel pump.
I use ferrite core shields on everything .
I use the type with a plastic case that snaps together around the wire . Very inexpensive, available on Amazon ,EBay .
The old school and still one of the best ways to find the source is to use an old cheap AM pocket radio tuned down to lowest end of the band ,around 540 . it will pick the culpret just about every time.
Old 08-17-2020, 05:23 PM   #8
Jackie McCracken
Liked 12 Times in 7 Posts
Cool Re: Wire Shielding EMI or RF Noise?
nothing wrong with solid wire and electrically it's actually better if done right. however, having said that stranded wire will not usually break because of vibration which solid wire will do, like a paper clip bent back and forth it will break at some point.
Some friends that run a sprint car had a similar goofy problem, make sure the distributor body is also properly grounded as the gasket will act as an insulator. You cannot have too many grounds, the more the better, including block, heads, intake, AND distributor.. and use the biggest wire you can physically get away with as modern ignitions pull a **** load of current. 12ga or bigger!
Jackie
Jackie McCracken is offline   Reply With Quote
Old 08-18-2020, 09:55 AM   #9
west coast
Liked 223 Times in 73 Posts
So I have had the same problem as Bobby, my data logs for the rpm is very squiggly. I tried almost every thing listed so far and gave up a couple of years ago on this. One thing that I did do was go back to my tach which is a 2 channel with drive line sensor, down loaded it and my logs looked clean on RPM. one thing that was mention by Tom I am going to try. if anybody gets there's fix please post how you did it.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
