Old 08-07-2020, 10:29 AM   #1
Stan Weiss
Stan Weiss's Avatar
Liked 733 Times in 384 Posts
Default Re: aerodynamic drag and body style
Originally Posted by Dragsinger View Post
Specifficly 3rd gen Camaro [which is what I am building] especially the drag cause by rear of body shape. What shape or spoiler can help?
Or, since it is 1/8 mile bracket racing, is it a non-issue?
To me, it seems it is important because the last 1/2 of track is over 80 MPH. Also, it you are racing into a head wind the drag will be increased.
Any feedback?
Hi Larry,
Aerodynamic drag is a function of both Coefficient of Drag and Frontal Area. Many times shown as CDA. If we keep the Frontal Area constant at 20 sq ft and the speed constant @ 100 MPH. A CD of 0.34 will produce an Aerodynamic drag of 51 HP while a CD of 0.38 will produce an Aerodynamic drag of 57 HP. The amount of Aerodynamic drag HP will increase with MPH and the HP difference between 0.34 and 0.38 will increase with increased MPH.
Stan
PS Maybe a graph which also includes 0.42 CD will show this better.
Old 08-07-2020, 10:58 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Stan,
somewhere I saw a chart about body styles and aero drag. [may have been your chart]
that chart showed the 3rd gen Camaro with a relatively low COD and the 3rd gen Firebird among the lowest.
I have even considered installing a 3rd gen Firebird ft fenders and facia on my Camaro. Would doing that be worth the effort plus finding a Firebird ft and painting it?
Is the frontal drag the most critical? With rear drag less of an issue?
Larry Woodfin 471W
Old 08-07-2020, 12:23 PM   #3
Stan Weiss
Stan Weiss's Avatar
Larry,
Frontal Area is the area that the car has when looked at from the front. You should be able to measure width and height and calculate your frontal area. Google calculate frontal area of a car What year is your car?
Stan
Old 08-07-2020, 12:51 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The aero package on the 91-92 Pontiac Firebird was reportedly the lowest CD of any GM car . Pontiac was very proud of that fact , and that was in many magazine articles . The frontal area was similar to the Camaro , but the front shape was way different . Rear shape was similar to Camaro , but air was able to flow under the spoiler.
Old 08-08-2020, 12:31 PM   #5
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I remember reading an article by Lingenfelter back in the early 70's.On his S/S 69 Camaro rag the car picked up a bit of MPH using only the front spoiler,and lost using the rear.The car would MPH around 115.In those days you would have to run both (as part of the SS package) or none at all.On my '71 it picks up about a 1/2 a MPH (more in a strong headwind) with the front spoiler...gsa612
Old 08-08-2020, 01:56 PM   #6
nickh
nickh's Avatar
Liked 640 Times in 192 Posts
Larry I ran a 82 z28 with the ground effects and I had a large rear deck wing, car was very stable at 185 mph in 1/4 mile..LOL
Old 08-08-2020, 02:27 PM   #7
Jackie McCracken
Liked 12 Times in 7 Posts
Cool Re: aerodynamic drag and body style
On a 79 Malibu wagon the factory rear spoiler is worth almost 3mph on car that runs just at 100 without it in the quarter.. and the reason for it is that it pulls air from the roof and routes it down the back window (to keep it clean in civilian life) which fills in the vacuum hole behind the car. and if you're wondering how big and powerful that "vacuum hole" is, it is what the cars that make turns use to create their ground effects downforce in sufficient quantities to be able to drive one across the ceiling upside down. The "vacuum hole" is also the reason behind drafting in nascar, if you can get in close enough it will damn near pull you along... need proof of what good aero can do? How about 174 on a bicycle...peddling.
what you really want to do with the front of the car is to smooth the air and keep it out from under the car, along the sides and roof you need to keep it flowing smoothly, and a the back you need to eliminate the "vacuum hole"...
Jackie
Name:	Bike Record.JPG
Jackie McCracken is offline   Reply With Quote
Old 08-07-2020, 12:53 PM   #8
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Stan,
Hey Larry watch this video. in this case the front end was a disaster for drag but the most gains were picked up with work done on the rear of the car.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 08-07-2020, 01:18 PM   #9
Stan Weiss
Stan Weiss's Avatar
Some numbers I have.
'84 Firebird Trans Am W62 Aero 0.30
No numbers for a '84 Camaro
'88 Firebird Trans Am GTA 0.31
'88 Camaro IROC 0.34
'91 Firebird Trans Am GTA 0.31
No numbers for a '91 Camaro
Stan
Old 08-07-2020, 01:34 PM   #10
junior barns
Liked 20 Times in 14 Posts
non-issue! unless you are running 130 mph in my opinion
junior barns is offline   Reply With Quote
