Old 07-06-2020, 05:33 AM   #5
james schaechter
Liked 1,434 Times in 299 Posts
Default Re: Jerico upgrade
If you are going to go with an upgrade, go for a much stronger clutchless set up. Stay away from the split slider set ups.
Gforce makes a true clutchless trans, a gf2400 four speed. I am sure it is good.
Liberty equalizers are also a true clutchless and I have run one for several years.amd love it.
Originally Posted by Jim Hawkins View Post
Question for stick racers.
What would be the next best upgrade if replacing a jerico 4 speed for a super stock car. Although this trans has held up well I feel I may be at the limit as to what this trans can handle. Broke a shift finger and replaced that and they now have a brace which ties 1-2 and 3-4 together which so far so good. 3rd gear shows wear prob. from burnout.
Now have a slight twist and runout on the 18 spline input.
I imagine a higher spline count could help that.
Is G Force the next step or step all the way up to a $$Liberty?
James Schaechter 3163 STK
