Old 05-24-2020, 04:44 PM   #1
Keith 944
Keith 944's Avatar
Liked 1,884 Times in 578 Posts
Default Re: "Live From" Numidia Dragway
Looks most likely like a TH35O intermediate sprag failure causing a drum explosion.
TH 400 will fail
It was a mopar so probably 904 or 727
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-24-2020, 08:55 PM   #2
Gmirza
Liked 253 Times in 95 Posts
Tough day for the mopars. Thats a Dakota hitting the wall and a dart or demon with the tranny explosion. That’s why they make us run blankets or shields. Any word on the driver, you know his foot was on that gas pedal.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 05-24-2020, 09:10 PM   #3
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Truck looked like an S-10 to me, however I wasn't there.
Old 05-24-2020, 09:50 PM   #4
Keith 944
Keith 944's Avatar
Truck was an s-10
And the mopar trans issue guy was in burnout box. Got out of car fine. Should have Rattled him a bit
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-24-2020, 09:50 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i see a piece of snap ring on the ground ,,if was to guess it was 727 and the drum blew up and took the rest of the case out is what i am seeing ,,
Old 05-24-2020, 09:59 PM   #6
Keith 944
Keith 944's Avatar
Scares me a little the car I’m running is a small block mopar with 727 and no blanket or shield runs low 11’s street/strip. 3750# coronet Was told only do burnout in 2 and high and don’t let it snatch while spinning
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-24-2020, 10:35 PM   #7
gmonde
gmonde's Avatar
Yeah ,,this is the second 904 I built ,turbo action manual valve body,,,second gear only burn out from the instructions, 904 stuff is smaller plus I did a aluminum front drum ,
Old 05-24-2020, 11:24 PM   #8
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I run valve bodies that hold the low and reverse band in first, even if you break the sprag you'll never turn that drum fast enough with a band holding it to explode the drum. Those valve bodies that don't hold the band should be thrown out.
