Old 05-04-2020, 07:52 PM   #1
63corvette
Liked 359 Times in 103 Posts
Default Re: NHRA Tech Cards
Originally Posted by Freddie View Post
I may be missing something but where are the online tech cards found?
Go to nhraracer then national event registration.
Once you log in.
Select your category.
At the bottom of your information page there is a box that says:
Click Here To Print Your Tech Card
That lets you fill in your information then print it with all your info on it.
I usually need to size it to fit my paper (standard size page).
Print it to the page fold it in half and you have a printed filled out Tech Card.
I usually print enough to get me through most or all of the season and keep them in the trailer.
I leave the track info blank and only need to fill out a few lines to have it complete.
Sign and date and you are done.
One of NHRA's better ideas at least for me.
Hope this helps.
Rick Cates
Canyon, TX
63corvette is offline   Reply With Quote
Old 05-05-2020, 06:55 AM   #2
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
I filled out the PDF and printed 8 or 9 of them. I guess I could use most of them for scratch paper the way things are looking.
Regan Wilson is offline   Reply With Quote
Old 05-06-2020, 09:31 AM   #3
Regan Wilson
You don't have to go to the slow NHRA site. Punch NHRA Sportsman Tech Card PDF in your search bar. Scroll down and you will see (2019 NHRA Tech Card- NHRA Reg). Click on the link and there it is.
Old 05-06-2020, 11:59 AM   #4
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Thank you found that one.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 05-06-2020, 08:59 PM   #5
Regan Wilson
You're Welcome.
Old 06-15-2020, 04:33 PM   #6
StompNDump
Just curious with the new online tech cards, since this will be my first time filling one out for S/G and S/ST. Do you have to check every single box on the tech card such as the ones that says, throttle, fire extinguisher, roll bars, roll cage, tires etc. ? These seem like obvious things a car would have but since im new to this I am confused. Dont wanna F it up.
StompNDump is offline   Reply With Quote
Old 06-15-2020, 06:26 PM   #7
ray4604
Just check the boxes you used to address when you filled out your card at the track. Then you will enter your serial numbers and expiration dates.
Ray Todd 4604 S/ST
ray4604 is offline   Reply With Quote
