Old 04-03-2020, 01:56 PM   #12
Rory McNeil
Default Re: Self Adj To Manual Adj Drums
Not sure when Ford switched to self adjusting brakes, but for certain my 57,8,&9 Ford cars came with 9" rear ends with manual adjusters. The starwheel on the manual adjuster has much larger, wider teeth, and a straight spring that connects the 2 shoes together at the bottom, and also rides on top of the starwheel, to prevent the starwheel from moving on its own. Another option is what I did with my 85 Mustang Stockers 8.8" . It had C Clip eliminators, which took up a lot of space, so what I did was trim down the female end of the adjuster, to allow a fine thread nut to act as a jam nut while maintaining the original length of the adjuster.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
