Old 03-01-2020, 09:26 PM   #21
B Parker
Liked 2,343 Times in 465 Posts
Default Re: 1.20 under at Belle Rose
I've been on here preaching for a while now about the AHFS needs to be brought up to date. How long has it been the same!!!! Not many of you jumped on board. In those kind of conditions I bet there are a lot of combo's that could go 1.20 or more under. I personal wished more went 1.20 under. BP
B Parker is online now   Reply With Quote
Old 03-01-2020, 09:27 PM   #22
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Mineshaft yes but 1.20 under is still an instant hit ofcourse. From what I was told the weather was it was incredibly fast and all I can say is under those circumstances he may have not known how fast he was going.
Fast enough to take .17 at finish line. More than a car length At 116 mph
Old 03-01-2020, 09:50 PM   #23
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
Does anyone know exactly what combo LaPorte was running, now that I think about it I thought he ran the 241 combo not the 272 350 combo?
Cooter, I hate to be the bearer of bad news but according to the tech card on Drag Racer TV it is a 245/272 350
Kenny Miracle
P/SA 310
kwm is online now   Reply With Quote
Old 03-01-2020, 10:04 PM   #24
G Schenck
Liked 81 Times in 35 Posts
It might have been a car length but it appears he was dumped at the stripe, which is hard to control.
Greg
G Schenck is offline   Reply With Quote
Old 03-01-2020, 10:33 PM   #25
Jason
Liked 8 Times in 5 Posts
Has anyone ever thought about taking enough weight out to be light at the scales on the first qualifying run? That way you could run flat out just to see how quick your car would run at that event. Even a 1.20 under run would not count because the car would be too light across the scales.
Jason is offline   Reply With Quote
Old 03-01-2020, 10:46 PM   #26
Mepprecht
Mepprecht's Avatar
Liked 68 Times in 26 Posts
that is completely false. 1.20 under and under weight is still a hit. look back at last year D6.
Mike Epprecht
94 caprice P/SA - SS/PA 265
Mepprecht is offline   Reply With Quote
Old 03-02-2020, 09:36 AM   #27
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
OK. I thought that was the reason for the "Mineshaft rule" to keep the combos from getting hit when the conditions were stupid fast like this past weekend. I didn't realize that if you still went 1.2 under you got hit with instant HP when the class met the mineshaft requirement . That probably needs to be changed.
Mike Pearson 2485 SS
Old 03-02-2020, 10:43 AM   #28
Bruce Noland
Liked 444 Times in 145 Posts
The ahfs is a flawed system as it is. There is no need to weaken it any further. But racers do need to use some common sense when in mineshaft conditions.
Bruce Noland 1788 STK
Old 03-02-2020, 11:42 AM   #29
rognelson777
Liked 135 Times in 74 Posts
i am still amazed in this day and age the only thing nhra uses is ET to change indexes. they need to use horsepower correction factor along with the ET that was run.
With the weather reading/ tracking technology that has evolved since the 1970's i have to believe there is a realative easy way to establish a system to decide if it was just great conditions or a great run.
as someone who raced on 0 elevation tracks (atco et al)and then going to indy, 1000ft +/- , can see there needs to be some way to level the numbers.
and i know there will still be arguements, but with hand held weather station devices able to calculate correction factors on the spot, there has to be a way to make it work 99pct of the time.
rognelson777 is offline   Reply With Quote
Old 03-02-2020, 11:57 AM   #30
James Perrone
Liked 1,855 Times in 433 Posts
The only problem I see is the car was on kill. And it shows
Now a little self control would have helped.
I will never understand why someone would try to go that fast you got a put a limit on yourself
james perrone 1290 STK
