327 super stock engine with holley carb
60 under motor has been best of 75 under Bow tie aftermarket block Jessel belt Jessel rockers Front drive distributor Ati balancer Aluminum oil pan Holley carb that was ran on motor A1 converter also available that was run with engine $6900 for motor complete with carb and converter Call or text 2516561072 Garage sell 9” strange 3rd member 40 spline 600 gear $800 4- 7” A1 converters $250 each 14”-2.5 springs several different 85-130lbs $50 set 12”-2.5 also $50 set Koni double adjustable coil overs 13.5”compressed 19.5 extended $375 (PRS) precision racing suspension coil overs double adjustable $500 2- sets alumna star wheel centers 5-4.5 $200 set 15x15 weld magnums 5”back spacing 5 -4.75 bolt pattern $700 pair A2000 new in box $400 Located north Alabama Can deliver most d2 races call or text can send pics of anything 2516561072 |
