Liked 341 Times in 67 Posts
351c stock eliminator engine minus carb. older technology,but good stuff. Never started after freshen. Make good backup or bracket engine SOLD
JPT c-4 transmission. full torrington reverse valve body. 2.43 low (stock) $1200 8 inch A-1 converter for c-4 Flashes about 5500 behind 351c $600 9 inch rear end for mustang drum to drum. 5.14 spool nodular 61.25 drum to drum case daytona support. aftermarket 31 spline axles $600 sale pending MSD 6al 6420 new in the box $125 SOLD MSD 6a 6201 new in the box (box has some staining) $125 sale pending MSD 2 step 8732 for 6425 new in the box $60 Summit sum850602 cdi new in the box (box has staining $60 BBC Edelbrock performer 2-0 intake. bolted on never used $135 BBF Edelbrock Victor 460 intake. used holley or thermoquad $215 Childs and Alberts rods 460 ford with bbc journal .990 pins used $125 Comp cams superstock roller cams various grinds $125 Mike Graham 602 540 4262 leave message M_Graham@testcrafters.com Last edited by Mike Graham; 08-16-2020 at 02:14 AM. Reason: sold items |
Liked 81 Times in 45 Posts
What is the first gear ratio.
Thanks |
2.43 low. stock ratio
Liked 706 Times in 283 Posts
Mike I will buy the msd6420 from you. I will call to come to you. I cant be at Nats. Thanks jeff
Could you tell me the measurements drum to drum and were you are at
I wrote you in private for the c4
Liked 364 Times in 138 Posts
PM sent Mike.
Dave Turner SS/GT #1153 |
Do you still have rear end if so please call for one to 779 three 479
