Liked 6 Times in 5 Posts
I recently purchased a Strange B3360 Master Cylinder Kit to "retrofit" into my 1970 Olds 442 Drag Car. I am replacing the OEM Cast Iron Manual Disc Brake Master Cylinder. I am finding that the "Push Rod" supplied in the Kit from Strange is approx. 1" - 2" too short. Strange does not offer any optional Push Rods and I can't find anyone in the Parts aftermarket that can tell me which Push Rod to use.
I've seen all kinds of basic "fixes" on the internet in chat rooms, etc., saying to simply.... "Cut" a grade 8 bolt to length and "grind off" the end to a ball".....or just "use some 3/8-24 all-thread rod," etc..... I know you guys in this forum are true, serious Racers that know your stuff and I am afraid of simply "grinding off a bolt" or doing a "cheesy" fix to the issue and want to do this the right way...mainly for safety reasons. Any recommendations would be greatly appreciated. Harold |
Liked 133 Times in 76 Posts
I used a Mopar style MC on my 3rd Gen Camaro. It wasn't bought from Strange but I don't think there is much difference. I had to make a rod to work properly. Jegs sells a rod kit with a clevis that you can make work. They also sell a boot for the rear of the master cyliner where the rod goes to use as a guide. One thing that is very important is to be sure there is no possible way the rod can be pulled out of the rear of the MC and drop. I removed my whole pedal quadrant and mocked it up on the bench. Then I welded in a flat piece of steel with a hole drilled in it as a guide for the rod. Also made sure I had a very positive pedal stop to prevent pulling the pedal back too far. There have been racers that have overlooked these items. Somehow their foot hooked under the pedal and when they pulled it out they dislodged the rod resulting in no brakes.
Liked 99 Times in 60 Posts
Eman has a good suggestion in ref to removing the pedal assemble and getting on the bench where you can fab up as needed to address the potential problems as he explained.
It is a serious safety issue so please be careful.
Larry Woodfin 471W |
Liked 21 Times in 13 Posts
I used an adjustable push rod with that MC
https://www.doctordiff.com/62-70-adj...-push-rod.html
Brian Carpenter Stock 1358 |
Liked 883 Times in 237 Posts
This part from Jerry Bickel Race cars is simple and inexpensive .
I use it on all my builds. Part number JBRC1064 $69.00
Thanks for all of the great ideas guys! I really appreciate the help.
Harold |
#7 | |
Liked 920 Times in 259 Posts
I've seen a number of cars torn up and people hurt as a result of inattention to this. |
#8 | |
And its not just Stock /SuperStock cars ,A lot of Bracket and Super class cars are also lacking adequate push rod retention.
Great info. Guys!
Thank you! |
Liked 242 Times in 81 Posts
This is what happens when the pushrod comes out
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
