Liked 2 Times in 2 Posts
1973/1974 Nova NHRA stock eliminator race car
$17,500 I would also sell several different levels - $9500 without wheels $11,000 full roller $12,000 with tranny $15,000 with backup motor $17,500 with new dart motor in it. Run as 1974 in I/SA - .40 under 50lbs heavy Engine - New dart block 350 PAC springs Bullet Cam Thin ring set All build details available 11 passes Transmission - New Long Motorsports Th200 Cheetah Valve body New Ultimate converter 3 passes on trans and converter Cheetah shifter Wheels - Weld Aluma stars front and back Hoosier light weight radial sidewall slicks Brakes - Wilwood disc brakes up front Aerospace disc brakes rear Strange master cylinder Brake pressure switch to fire two step Suspension- AFCO double adjustable shocks up front Calvert shocks rear Cal-trac rear suspension Landrum springs Global West Del-A-Lum bushings up front Rear- 10bolt with moser axles Moser spool 5.13 gears Fuel System- MagnaFuel pump 8an braided steel front to back Fragola fittings Product Engineering high flow regulator Deano’s quadrajet Electronics - Leesh power board MSD 7AL2 MSD 2 step Moroso switch panel All new wiring throughout car Last edited by hevychevy; 02-15-2020 at 11:16 AM. Reason: Left off price |
Liked 55 Times in 26 Posts
Let me know if you decide to sell spare motor
