Old 01-29-2020, 01:43 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Good thing pinned studs are still legal......All the racers with them can breathe a sigh of relief...…..LOL
P.S. I did pin a lot of studs but it was at least 30 years ago and a lot more....
Rich Biebel
S/C 1479
Stock 147R
Old 01-29-2020, 08:10 PM   #2
Tom Broome
Liked 88 Times in 43 Posts
Yeah......about that. I also hadn't pinned any studs in a long time either. Racers moved on to better options.
Then......the Magazines and the Internet "Experts" convinced all these streetcar folks that they needed Vortec heads as a "budget" performance option. You put one more ounce of spring pressure or cam lift on those things. and the studs seem to fly out. Once they see that the guides have to be cut and new seals installed, there's no room in the "budget" for screw-in studs. Now pinning becomes an option again.
P.S. I can't describe how much I dislike pinning studs nowadays.
Tom Broome is offline   Reply With Quote
Old 01-30-2020, 10:23 AM   #3
bert powell
Liked 34 Times in 12 Posts
Who is going to be the first to take a bbc oval port head and mill 1" off the intake flange of head below the valve cover bolts? Should gain 50-60cc to open up the port.
bert powell is offline   Reply With Quote
Old 01-30-2020, 01:17 PM   #4
bykr
Liked 167 Times in 81 Posts
Yeah, after the crying, NHRA backing down leaves the door open for more "innovation".
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 01-30-2020, 05:03 PM   #5
bubski
Liked 165 Times in 60 Posts
Once again the "innovators" get there way !! Break out the 85b n mill away !! Can anyone guess whats next to come down the road ??
bubski is offline   Reply With Quote
Old 01-31-2020, 09:27 AM   #6
Tom Broome
Valve seat replacement is legal now. Chamber modification is legal now. Combine the two options.
That's all I'm allowed to say.
Old 01-30-2020, 02:49 PM   #7
SSDiv6
Bert,
Do you even know what you are talking about?
Gain 50 to 60 cc's when the rules allow you to port, epoxy and epoxy the cylinder heads?
Old 01-30-2020, 02:58 PM   #8
Joey Bohannon
Liked 61 Times in 22 Posts
Bert knows exactly what he is talking about! If they cc without the spacer plate there is a ton to gain. And if there wasn't gains to be had in port volume, then why do they make'm. Air speed can still be retained with more volume.
Joey Bohannon is offline   Reply With Quote
Old 01-30-2020, 03:40 PM   #9
SSDiv6
It is measured without the spacer and not all engines use a spacer. There is a lot more to to volume to make power with cylinder heads.
Old 01-30-2020, 10:32 PM   #10
bykr
You just don't get it. So why do you think they're doing this? The guy that was doing it obviously thought it had an effect.
