#91 |
Liked 535 Times in 86 Posts
#92 |
Liked 544 Times in 213 Posts
#93 |
Liked 163 Times in 53 Posts
no Bryan,...nobody in stock runs that... You can run it in SS.
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#94 | |
Liked 55 Times in 14 Posts
It helps to go fast when you race a combination with a relative soft HP factor...just saying. |
#95 |
Liked 748 Times in 137 Posts
#96 |
Liked 13 Times in 4 Posts
This, in my opinion, is just another "stretch" of a rule. The question of right or wrong and our opinions of it probably matter very little at this point. The problem here is somewhat the same as it has always been...NHRA. If these heads went through tech and were approved 2 years ago then they are problably always going to be legal from here on out, just like pretty much every other rule that has been "stretched" over the years. Honda rod journals, modified combustion chambers, aftermarket cranks, gas ported pistons, blah, blah, blah...
A couple thoughts... 1. I commend Eric Jones for asking for permission before he started doing this modification. Wether it be for a mopar, ford, chevy...whatever. Its not the way things have been done in the past for the most part and I for 1 look at it as the respectable thing to do. 2. I have spoke with John Gulius on a few occations...dude is the Don Garlits of super stock motors for sure. He is an innovator no arguments on that. But I feel this is just the straw that broke the camels back or the excuse he needed to say I'm done. There is no way this is the only reason he quit...To my knowlege he's in his 70's, I'm sure he has his reasons. For the record... We have 2-L98 motors...one has some modifications done that become illegal based on this new ruling if it stands, the other is legal either way. THE MOTOR THAT IS LEGAL IS FASTER!!!!! That is all...I'll head back to the couch and wait for next season to get here! |
#97 | |
Liked 1,034 Times in 368 Posts
Don't bring his health into it, or his age. He's in better health than you and me put together. His hobby is hunting in mountains in Afghanistan, Pakistan, Russia, Iran, at peaks of 15 thousand feet that will make a common man wilt. A friend of ours was sharing a room with John while at the races. He had the crap scared out of him about four in the morning, only to turn on the light to see Gulius doing push ups in between the beds ! One thing for sure,his age or health didn't bankrupt him.....
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 12-17-2019 at 09:55 AM. |
#98 |
Jeff, I appoligize if you took my post wrong...
I didnt even imply Johns health was bad, I only feel this can't be the only reason he decided to quit, especially considering the rule is probably never going to be implemented. |
#99 |
[QUOTE=cbohannon;603992]This, in my opinion, is just another "stretch" of a rule. The question of right or wrong and our opinions of it probably matter very little at this point. The problem here is somewhat the same as it has always been...NHRA. If these heads went through tech and were approved 2 years ago then they are problably always going to be legal from here on out, just like pretty much every other rule that has been "stretched" over the years. Honda rod journals, modified combustion chambers, aftermarket cranks, gas ported pistons, blah, blah, blah...[QUOTE]
Does anyone really think that the tech department just lets stuff slide right thru teardown or approves modifications that are clearly against what Stock and S/S stands for? Like all businesses the tech department is probably governed by powers higher than themselves. Those higher powers more than likely have the final say on rule changes and what is deemed illegal or legal, even though the higher powers may know very little about the mechanical workings of racing engines, especially Stock and S/S. |
#100 |
I'm not knocking the tech guys at all, especially the guys that are there every weekend trying to make things fair and safe for all of us. But there is documentation from the nhra tech dept that approves these type modifications.
