Old 12-09-2019, 06:58 PM   #1
rx dealer
Liked 53 Times in 13 Posts
Default Re: Mid plate Stick car
I did not run a mid plate. I had steel tubing about 1/2 inch in diameter, with hiem joints on each end. one end went to the trans cross member and the other end on the clutch can. this was hooked up on the passenger side of the car. it's simple and rock solid. Luke
rx dealer is offline   Reply With Quote
Old 12-09-2019, 07:14 PM   #2
Jim Caughlin
Liked 805 Times in 245 Posts
I built a tube cross member that bolts to the frame and the flange on the bellhousing. I'm happy I did because I had a flywheel come apart a few years ago, it broke the back of the block off, the crossmember held everything together until I got the car stopped.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 12-11-2019, 11:28 AM   #3
lca1971
lca1971's Avatar
Liked 3 Times in 2 Posts
Yes, several different ways you can do it. It also depends on where the eng and trans bolt together in relationship to the firewall.
lca1971 is offline   Reply With Quote
Old 12-11-2019, 11:30 AM   #4
lca1971
lca1971's Avatar
Pictures?!?
Old 12-13-2019, 05:53 AM   #5
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Quick dumb question..mid plates are not allowed in Stock?....correct?
Will Lamprecht
1965 Impala I/S
Old 12-13-2019, 08:10 AM   #6
Liked 10,714 Times in 2,230 Posts
Correct
