Old 12-08-2019, 07:39 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: Duramax Allison issue
Originally Posted by Barry Polley View Post
Works so well in the truck I’m tempted to try it in the race car.
I've used Transynd in Powerglides behind some big HP in an attempt to get better pump life when the pressure gets over 225 psi and it definitely seems to help. It is a full synthetic and a higher viscosity than regular Dex 3 fluid. Castrol was the original supplier when Allison wrote the specs for the fluid, TES-295. They have since added a few suppliers to the approved list. As far as what to use in an Allison, I wouldn't use anything that they haven't approved to TES-295.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 12-16-2019, 06:43 PM   #2
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Allison part #. Change every other oil change. Deep pan and Transynd 30k. Transynd doubles the service life in conjunction with additional ATF (deep pan). Don't forget to take the magnet out of the old filter, to put in the new filter.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
