Old 12-06-2019, 08:01 PM   #8
Barry Polley
Guest
Posts: n/a
Default Re: Duramax Allison issue
Originally Posted by lorenr View Post
I don't know much about the Duramax Allison, but I've needed to service both the Allison 3000 & Allison 4000.
When Allison switched from Dextron ATF type fluids to their Transynd fluid, I noticed the stuff is very thick and probably won't flow through most standard transmission filters.
Kind of an odd type fluid, but if you regularly maintain the 3000 & 4000, they are literally indestructible. Kind of need to do what they say.
Loren
Switching to the Transynd fluid or as I did Delvac approved fluid the transmission is smoother. If you tow heavy you might consider using the better syn fluid.
