Old 11-26-2019, 05:04 PM   #13
west coast
Liked 223 Times in 73 Posts
Default Re: Index Change Rumor
There are a lot of you that need to quit drinking the kool aid, put your bong down and lay off the PBR's.
This is Class racing, if you don't want heads up get the F out. What the F are you thinking this is a performance base class.
Do the combos need to be even out YES
Changing the index only helps the fast guys and gals
To make this **** work, the Afhs
Put Indy back in the mix.
Get rid of mine shaft rule.
Quit publishing the Avg's
Change the triggers
Something needs to be done with combos with lots of cars, as posted above example the LS, look at 69 Camaro, i am sure there is more examples of these.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
