Old 11-05-2019, 07:02 PM   #1
RJ Sledge
Liked 288 Times in 90 Posts
Default Re: Street 427 Ford question
I believe that the Edelbrock FE heads had a MR ports design, but if you take a intake gasket like you are running now and lay it on the heads with the bolt holes aligned it will tell you what you need to do. Worse case is port matching your intake manifold to the heads or vise versa.
RJ
RJ Sledge is offline   Reply With Quote
