Liked 68 Times in 22 Posts
Is it legal to run a regular old style Chevy block rather than a LT1 block in a 98 Camaro in stock eliminator ?
Liked 79 Times in 22 Posts
Yes, as long as the main bearing size is the same. In other words, you can't run the small main journal Chevy pre-1968 block.
The blocks are NOT a direct replacement. The LT block has a completely different cooling routing system, unique front drive distributor, different timing cover, etc. Others have converted an LT engine to a earlier generation block, but it's not that easy. |
Liked 693 Times in 205 Posts
Maybe in Superstock, but in stock you must use the Opti-spark, which requires the LT1 block.
Liked 109 Times in 32 Posts
MSD and stock GM Opti-spark's will work the traditional style sbc blocks.
Drew Whalen Stk 3186 |
Liked 239 Times in 114 Posts
Standard sbc water pump with spacers to clear distributor. Water flow can be either direction, these motors don't see enough temperature to need the reverse cooling.
Drew Whalen Stk 3186 Last edited by Whalen3186; 10-10-2019 at 11:44 AM. |
#7 | |
Seems to me the issue is how to adapt the front cover to the old style block . Isn't the shape and bolt pattern very different . Also wouldn't the water in the heads be deadheaded . |
Liked 544 Times in 213 Posts
Rare they are but they did make Bowtie LT-1 blocks....
They were made in a std 4" bore size and a larger bore....4.125" I took delivery of 1 for someone who found 2 or 3 available somewhere. I was aware that Bowtie blocks could be adapted for use in SS with a belt drive distributer but never knew of or saw one in Stock adapted somehow to drive an Optispark distributer with the LT-1 timing cover....on a std type block.... An Interesting topic....
#9 | |
Liked 534 Times in 143 Posts
There are two water passage plugs on the heads that you remove with an adapter that bolts on to adapt to an -AN fitting. A standard SBC water pump with enough spacers to make a good border wall will be necessary to clear the Optispark or MSD. I suggest that you use the largest water return lines and -AN Y fitting coming from the heads that will fit. Hope this helps. |
I forgot to mention that the reverse cooling for these engines was a way to somewhat battle detonation on pump gas and utilizing higher compression for a street car. We can and do run much higher octane with our racing fuel so it is a moot point on how it cools from the top down or bottom up.
Just make sure it cools. |
