Old 10-01-2019, 07:04 AM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 555 Times in 216 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
I'm honestly amazed after the dyno runs and where the power was, how far this thing will rev, in lower gears it will hit 7500 no problem.
A stock Z/28 302 would rev to 8000 if you let it back in 1969-1970
I drove one and that’s with stamped rockers and springs that had about 100lbs on the seat IIRC..
The difference from a hydraulic cam engine to a solid cam was like night and day.
Rich Biebel
S/C 1479
Stock 147R
Old 10-01-2019, 09:01 AM   #2
Rich Biebel
My friend Joe Demarzo making a real nice pass this past Sunday at MG
https://www.facebook.com/larry.guest...4756815921752/
Rich Biebel
S/C 1479
Stock 147R
Old 10-01-2019, 10:40 AM   #3
Nmbr1GMfan
Absolutely
Todd Greene
Old 10-03-2019, 11:17 AM   #4
Casey Miles
Liked 508 Times in 92 Posts
Please tell that to NHRA, the solid lifter engines were penalized with HP from the factory and now that all the hydraulic engines can use solid lifters they didn't get HP. But the solid lifter engines didn't get a reprieve of HP.
Casey Miles
Stock
Old 10-03-2019, 12:04 PM   #5
Liked 5,145 Times in 1,964 Posts
Casey Miles
Stock
1970 LT1 , 360 hp, now 320 with manual trans. ;-)
Old 10-03-2019, 04:58 PM   #6
Nmbr1GMfan
Really really hot here at VMP, made a clutch adjustment and two test runs today. About .05-.07 slower than our test last week but Good weather is on the way. Too hot so I'm going in the a/c for a bit then doing carb work tonight. Shot an in car video and you can clearly hear the car labor in high gear till maybe 6100 then takes right off till about 6900 at the finish. Making some shift light adjustments for tomorrow.
Todd Greene
Old 10-03-2019, 07:01 PM   #7
Rich Biebel
That’s awesome ! That dyno you tested the engine on must be awfully stingy on readings or something changed a lot. Those engines generally pick up a lot in good air. Good job !
Rich Biebel
S/C 1479
Stock 147R
Old 10-03-2019, 07:39 PM   #8
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
if stockers are out first tomorrow 9:00 am ,that et will be quicker ,get your race pack ready to log those O2's
your getting there ,, I need to find more as well ,,I will be watch d1tv
Old 10-03-2019, 09:50 PM   #9
Nmbr1GMfan
I'll assume the air will be better here on out, I don't know about the car but I know I'll feel much better about it.
Todd Greene
Old 10-03-2019, 09:44 PM   #10
Nmbr1GMfan
Yes, I was told the dyno was not a hero machine.
Todd Greene
