#1561 |
Liked 165 Times in 59 Posts
race pack (imo), if you use it all the time its great, but its a pain if you only use it once and a while ,, I have a RPM data logger and it is real easy to use and set up ,
your install is nice and neat,, mine started of that way but added a bunch of stuff ,, it got out of hand |
#1562 |
Liked 2,738 Times in 965 Posts
#1563 |
#1564 |
Liked 333 Times in 180 Posts
They are simply recording data from a run--"you" have to make any adjustments that you feel are necessary--- over time after reviewing the records you have been keeping of each run you will make the "correct" changes to your tune up to correlate a previous run mimic your next run-- you are going to have to enter additional info or keep the info in your log book such as track temp/humidity/grains/density altitude/ etc. to see what your car run in similar conditions---it is not an ET or MPH predictor--- FED 387
#1565 |
Liked 242 Times in 81 Posts
Racepak is great if you remember to turn it on so it records the run. At Indy driver forgot to turn it on in 2 runs cost him a class win. At Norwalk remembered to turn it on .2 quicker. He just won class at the Sports Nats.
Moral of the story if you got it use it.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#1566 | |
Liked 319 Times in 82 Posts
#1567 |
Liked 237 Times in 126 Posts
Start with pg. 22 of the manual for rpm trigger setup. Section 5. That's a nice piece. Maybe start with pg. 1
![]() I'm trying to piece together Innovate Motorsports products for data as a Racepak is out of my budget. You have such nice stuff.
#1568 |
Liked 7 Times in 5 Posts
our grid will starts to log once it sees the launch rpm limiter activated and above 2500rpm which is nice and it ends up recording every pass we don't have the arc module to record output shaft or driveshaft rpm because of the legality around running it i wish they would make a driveshaft module without the built in traction control stuff for the grid.
#1569 |
hahaha
Todd Greene |
#1570 | |
Todd Greene |
