Old 08-22-2019, 08:29 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default SBC tall deck rod length option
I have a decision to make and am requestion experienced help.
I have a Brodix aluminum small block with 9.30 deck height. [4.125 bore x 3.80] the same short block has a 6.250 rod and a piston with 1.150 compression height. This is complete, balanced, running assembly, operating without problems but it is a high RPM, high maintenance package
I am removing the radical 11-degree heads and sheet metal intake and replace them with a nice set of fully worked Brodix dragon slayer heads and fully worked Super Victor II intake. [the 11-degree parts are all for sale and the setup is too radical for my usage]
I will be buying a shelf 23-degree piston with the pin relocated, several piston manufactures offer relocating a self stock pin for a small cost.
I expect this engine to make around 720 horse with an operating range between 6200 - 7800 RPM. It will be in a 2900 pound door car with an expected 5.90 1/8 ET. It will be Methanol fuel with carb.
Now to the question, keep the 6.250 rods or replace them with 6.0 rods? I will need to buy pistons either way and of course, if the 6.250 rods will perform as I want, it will save the cost of rods.
Larry Woodfin 471W
Old 08-22-2019, 11:34 AM   #2
SSDiv6
Liked 1,594 Times in 583 Posts
Default Re: SBC tall deck rod length option
Larry,
I would go with the 6.25" rod length.
The engine will have a better rod ratio for the cylinder heads you pl lan to use.
