Old 08-19-2019, 06:33 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: O2's in collectors
You will see lean spikes at rpm below about 5000....
I had an O2 recorder on my Firebird LT-1 stocker and had the sensor in the collector......I added some length to it and it was better but still some very lean false readings....
It was still usable using the "smoothing" feature of that recorder to dampen the spikes......
Rich Biebel
S/C 1479
Stock 147R
Old 08-19-2019, 06:41 PM   #2
Kirk Morgan
Liked 80 Times in 44 Posts
The low RPM readings will not be accurate. As Rich said use a collector extension for a more accurate reading. For idling in the pits we made a 12 inch collector to adjust the air fuel ratio.
Kirk
Kirk Morgan is offline   Reply With Quote
