Liked 84 Times in 21 Posts
I’ve got a couple cases each of Valvoline Racing Oil 10w30 part number VV850 and Valvoline VR1 10w30 part number VV205. I called Valvoline Tech for info on these 2 products and was told they were both the same product but no longer a current part number and that they were over 5 years old. He stated DO NOT use them because ANY bottled oil only has a 5 year shelf life and the additives could settle out and or dissipate. He suggested shaking the bottle may or may not help but still to dispose of them and buy new product. I also read on the Valvoline Racing Oil site about these oils with Zinc in them are corrosive and should not be left in the engine. I am not a petrochemical engineer and this is all new to me. Thoughts???
Liked 348 Times in 152 Posts
Wow. I had a similar (bad) experience with the Valvoline tech line about 7 or 8 years back, apparently they haven't gotten any better. I went through 3 "techs" before I was able to speak with an engineer. He stated that the VV850 was a non-detergent oil, which was the reason it was labeled "not for street use", and told me it would only last for 300-400 miles. The VV205 is what he recommended I change to, as it had almost the same zinc content, but would resist heat and last a normal length of time for a street application.
OK, that part was factual, the part about oil being no good after 5 years strikes me as fictional - I'm currently using oil purchased in 2008 (got a killer deal and stocked WAY up) and have had no issues. And, yes, I have looked in the bottom of the bottle, and there is no separation or residue. And I don't shake it, either. It's very common for some additives to settle in the bottom of the pan, I see it quite often doing freshen ups. It doesn't seem to hurt a thing. I'd use it for sure, the VV850 was about the best oil I ever used in a race engine.
Phil Molski PMR Performance S/C 1623 |
Liked 251 Times in 125 Posts
Oil threads always go crazy, it seems. I'd ask here: https://www.bobistheoilguy.com
Liked 20 Times in 15 Posts
I think there is a U tube video of how they blend motor oil. There are solids(plastics, for a simple term) that are blended into the base oil in addition to chemicals. They are mixed for hours to make everything go into solution. I've seen military and industrial 55 gallon drums that were sitting for years. Upon decanting, some looked like contamination had occurred. After sending samples for testing, just contents coming out of solution. Although, never make assumptions!
