Old 08-16-2019, 02:50 PM   #1
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: spiral or ring type piston pin retainers
Originally Posted by Nmbr1GMfan View Post
Rich, I agree with everything you've said. Why the piston manufacturers have gone to a round wire lock I can't comment on, I just don't know. What I do know is a round wire lock will not work if the piston manufacturer doesn't machine the groove properly. Not sure if the same applies to a spirolox groove or that type of lock is more forgiving to machining discrepancies.
Unfortunately in this day and age manufacturers have to have something new to help them sell and be different enough to be the latest "new & improved"
Sometimes change is good if it's made for the right reasons.
Sometimes change is bad if it's made for the wrong reasons.
I have been racing with my partners for 50 years and always on a tight budget. No money makes it difficult to recover from adversity.
We raced what we built. The dollars spent had to produce.
Why would I risk our racing money on a trick of the week.
I know that I will take some heat for this post, but that's OK because I've handled heat my whole life...
As I remember back there was a very well known Junior Stocker guy that had written on his car "Trix are for kids" and it's still true today.
Bob Mulry 7516 STK
A & M Motorsports
Old 08-16-2019, 05:53 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 547 Times in 214 Posts
Here is a joke that might fit for this...
Consider the new round wire pin locks "the green alternative "
In my experience if it says its "green" It just doesn't work worth a you know what....
Plenty of modern things are better and may take some getting used to.
Plenty are not and you regret getting sucked into the marketing...
I would assume a round wire lock would work fine in a properly machined groove with a pin finished the way it would need to be to work with that lock....and all proved by testing...
But exactly what is the reason to make a change from what has worked for decades.....
You have to ask yourself why did they make this change.....There is NO advantage or improvement since what they changed was not failing....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 08-18-2019, 05:52 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
I have engines with both dual spiral locks ,and the round wire rings.
Mahle has the round wire clips in their specialty performance line.
Since the wire ring engine has not been pressed into service yet ,I cant personally attest to their durability.
That being said , my finger tips were in much better shape after assembling the engine with the wire clips !!
Back in the 80's the machine shop that did my work was building some mighty successful Dirt Modified engines with the wire clips , I cant remember them having any failures. . ...Plus they had some Cosworth engines there which also had them.
Old 08-18-2019, 10:45 PM   #4
spike1
Liked 53 Times in 16 Posts
I have been running round pin rings (CP) for over 2 years now (200 runs) in my 5.7 drag pak up to 8400 rpm and never had a problem with ring clips, pins or piston.
spike1 is offline   Reply With Quote
Old 08-19-2019, 12:10 AM   #5
rawhide
Liked 7 Times in 5 Posts
I have not seen a Cosworth piston that did not have round wire rings in them and they started business in 1959. The last V8 Ford Formula One engine they did ran at 19500 rpm without any failures that I can remember. Even flathead Fords had round wire locks.
rawhide is offline   Reply With Quote
Old 08-19-2019, 08:46 AM   #6
Rich Biebel
I was in the engine machining and building world for many years and not once can I recall seeing round wire pin locks....from any of the major piston manufacturers.
Round snap ring type was common.....double per side and then spiral locks were the most common.
Yes they tear up your fingers and usually end up with some blood involved.
They made a tool for them but I developed a pretty easy method of getting them in and out.....no blood....usually...
I would guess the round wire lock does not pound out the groove like a flat lock does making it harder to disassemble pistons after some use...
I also assume the round wire lock groove is cut to fit the lock and if done wrong bad things happen...…
I usually Learn something new everyday...but I'm sticking with spiral locks.....LOL
Rich Biebel
S/C 1479
Stock 147R
Old 08-21-2019, 02:26 PM   #7
Tom Broome
Liked 88 Times in 43 Posts
I still prefer spiral locks also. But there were a few somewhat major piston manufacturers many years ago that utilized round wire locks. One you might have heard of....Cosworth. We used lots of them in the 80's on Buick R&D at the shop I worked at. Cosworth seemed to have it figured out, even the "on center bore" V6 Buicks still had rod offset issues and I can't recall a single Cosworth piston pin issue.
Tom Broome is offline   Reply With Quote
Old 08-21-2019, 03:31 PM   #8
Bob Mulry
Bob Mulry's Avatar
I'm not sure Rich, but I think that you might be referring to the doubled up Tru-Arc snap rings.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 08-21-2019, 05:11 PM   #9
Liked 5,138 Times in 1,961 Posts
Bob
We used double Tru-Arcs a lot. Sharp side facing away from each other..to the outsides.
Again, no failures.
Also used single spiral locks too.
Old 08-21-2019, 07:05 PM   #10
Rich Biebel
Bob
No Bob.....What Mark said was spot on about Tru Arcs....exactly what we used and how we installed them..
I was thinking of some old engines and oddball stuff that we occasionally worked on....Round wire locks...
In my long working career I once worked in a pretty famous restoration shop here in NJ.....They did all old cars and specialized in Packards and other high end old cars....I worked on some real interesting cars for a while.....I worked in the mechanical end.....engines, drivelines,brakes, you name it.
Was to slow a pace for me and the pay was poor.....Rich guys spending a fortune and we got paid coolie wages....LOL
Like they say today.....He gone....that was me....
Rich Biebel
S/C 1479
Stock 147R
