Old 07-07-2019, 09:22 PM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default MSD 8732 2 step sporadic fail
Has anyone experienced and fixed the sporadic 2 step not working when you least expect it?
I have 2 friends that have also had the issue.
This has happened on my 68 Camaro, as well as my S10. My S10 has a 1 year old 8732 that I bought new.
Both have the newer digital 6AL.
In order to prevent it, I've had very good success turning the dials prior to every run.
One friend added the MSD noise filter and hasnt had the issue since, so I added one in the S10 last week. No issues on Saturday with 5 runs and not touching the 2 step. Today, bam in round 2.... Straight to the converter.
Thank you,
Clark
Old 07-07-2019, 11:30 PM   #2
Mike Graham
Liked 341 Times in 67 Posts
Default Re: MSD 8732 2 step sporadic fail
Best way to fix that POS is a hammer skillfully applied to the face a minimum of 3 times.
Mike Graham is offline   Reply With Quote
Old 07-08-2019, 12:35 AM   #3
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
I've experienced that too. I wasn't sure if it was the 2 step or the brake pressure switch. I put in a different type of pressure switch and haven't had a problem, but then I haven't put very many runs on it either.
Dave Muller is offline   Reply With Quote
Old 07-08-2019, 07:32 AM   #4
Rsmith38
Liked 28 Times in 15 Posts
MY setup - Old 6AL and 2 step using old Ford brake pressure sw - Has been working without fail for 10 years - Can't help with the digital - but seems like the ignition box isn't the problem - the 2 step or its activation is!
Rsmith38 is offline   Reply With Quote
Old 07-08-2019, 10:18 AM   #5
Eman
Liked 133 Times in 76 Posts
I put a very small LED light on the dash that is wired to the 2 step activation wire at the 2 step. It lets me know I have enough pressure on the brakes and that the 2 step is getting power. I have had it go straight to the converter and that is why I put that light on. In my case it was a failed connection but I could have seen it and saved the round possibly. Only other time I had problems was when the chip fell out of the 2 step. Makes you wonder why they didn't make a retainer for the chip. Now I have a zip tie around it and tape, very professuional looking.
Old 07-08-2019, 01:51 PM   #6
cad
cad's Avatar
I like the LED idea.
This is the 2 step with no chip which is only on the 6425 Digital 6AL.
https://www.jegs.com/i/MSD-Ignition/121/8732/10002/-1
Old 07-08-2019, 02:18 PM   #7
GTX JOHN
Just prior to staging, I put my cars in neutral/Apply Brake/Check two step.
Many of my sporadic problems have been in connections = defective plug in wiring
on MSD.
Their quality is not what it used to be!
My .02
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 07-08-2019, 05:29 PM   #8
cad
cad's Avatar
Are there any alternatives??
Old 07-12-2019, 04:10 PM   #9
cad
cad's Avatar
After talking to MSD for the 5th year in a row, we got hold of a different tech.
Will see....
Old 07-12-2019, 10:28 PM   #10
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Footbrake
Lane Weber
