Old 06-26-2019, 01:36 PM   #1
Greg West
Liked 52 Times in 22 Posts
Default Re: Dumbo The Flying Elephant
McMaster-Carr may have .007" shims. I have gotten .004" - 006" shims with various diameters from them in the past.
Greg West is offline   Reply With Quote
Old 06-27-2019, 04:26 PM   #2
Liked 10,756 Times in 2,236 Posts
In this build I tried some Proform tools: the electric ring filer and the 4.125 ring compressor. Both were POS's. The ring compressor was 4.126 to 4.132 not round and not going to work in a cylinder with very little chamfer @ 4.124 ID. Ring filer was so loose the indicator moved 008 to 010 just by turning it on. I did buy a AARP compressor that worked well
Break is over back to work.
Old 06-27-2019, 06:07 PM   #3
MR DERBY CITY
Liked 7,965 Times in 1,524 Posts
Larry, can’t wait to see you, Patsy and the car at the track...I have gotten quite a few PM s regarding the stocker hood issue with mopars...
...so I will just ask away ?? Will this car have the correct hood on it...asking for a friend .....
Old 06-27-2019, 06:23 PM   #4
The top of the car is red so we painted the hood to match. It looks like the correct hood. With some "Hillbilly engineering'' the hood will be wired shut. The cool part about the car is that when you touch the door handle the window roles down just a bit. And when it closed it roles up like magic. I sure hope the battery stays charged so I will be able to get out after a run. I think since it's a 2015 it will still be in warranty until after the election.
Oh ya tell your friend "Thanks for asking"
Old 06-27-2019, 07:58 PM   #5
Dissident
Liked 73 Times in 36 Posts
Larry,
While others might worry about hoods 'n stuff....I just want to compliment you on that laser etching on the piston....nice touch. I would never have thought of that. LOL
Glad you are enjoyin' the fun parts of making things happen.
Best to you and yours,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 06-28-2019, 08:00 AM   #6
Maybe it is a mistake but the pistons only varied .5g and I did not go after that. Top to bottom the parts were pretty good, some of them just didn't like each other. Assembling the heads was a real chore with big hands in tiny spaces. I bet the Ford folks have all kinds of fun with the four valve 302 -327
Old 06-30-2019, 07:54 AM   #7
Engine management hardware, I have an early TPI IAC with a late model adapter plug on it to interface with the ECM. Almost forgot the TPS, MAP, and the air temp sensors. All this stuff looks good on the computer screen but no one has any information about the part. I'm not trying to get the secret recipe for KFC, just what size thread, bolt spacing, or style plug.
