Liked 10,714 Times in 2,230 Posts
Short block is assembled. Patsy will post pictures later. The deck has a slight slope to it. We will try to fix it when block needs to be resurfaced. Having the block like this is is costing me a little bit of compression, but being a Hemi newbe I will take it. I tighten the rod bolts to a stretch of .005 - .0054. I hope the picture of the NHRA pistons is clear.
Camshaft and lifter bushing. Up close and personal
In the morning that head will be done!! That is assuming that we have proper piston to valve clearance at split overlap.
Liked 249 Times in 48 Posts
Great pictures.
Thanks for keeping us up to date. Pete |
Liked 52 Times in 22 Posts
McMaster-Carr may have .007" shims. I have gotten .004" - 006" shims with various diameters from them in the past.
In this build I tried some Proform tools: the electric ring filer and the 4.125 ring compressor. Both were POS's. The ring compressor was 4.126 to 4.132 not round and not going to work in a cylinder with very little chamfer @ 4.124 ID. Ring filer was so loose the indicator moved 008 to 010 just by turning it on. I did buy a AARP compressor that worked well
Break is over back to work. |
Liked 7,939 Times in 1,520 Posts
Larry, can’t wait to see you, Patsy and the car at the track...I have gotten quite a few PM s regarding the stocker hood issue with mopars...
...so I will just ask away ?? Will this car have the correct hood on it...asking for a friend ..... |
