Old 06-24-2019, 04:03 PM   #11
Superfan1
Superfan1's Avatar
Liked 2,638 Times in 440 Posts
Thumbs up Re: Factory Stock Showdown - Norwalk
Thanks for the update Bill. Just curious and wanted to make sure Don was A O.K.
Ron, to the best of my knowledge, Don is fine. He wasn't at the D1 race at Maple Grove last month, but while I was there I spoke to his engine builder Jim D' Amore and nothing negative was mentioned.
Bill Seabrooks - superfan1
Bridgeport, CT
Old 06-24-2019, 05:30 PM   #12
troublemaker427
troublemaker427's Avatar
Liked 64 Times in 23 Posts
Default Re: Factory Stock Showdown - Norwalk
They had an oiling issue with the new engine. Should be ready for NMCA Norwalk & Indy.
Jody Aberts
Troublemaker2
1966 Fairlane 427
Old 06-24-2019, 06:00 PM   #13
Superfan1
Superfan1's Avatar
Thanks Jody, at Norwalk Chris Holbrook mentioned that they may have encountered an issue with the new engine.
Bridgeport, CT
Old 06-24-2019, 06:03 PM   #14
pmrphil
Liked 348 Times in 152 Posts
All of the Mustangs at Norwalk were running the 327 engine which is a new combination for 2019. It is based on the 302 block with a longer stroke. The word in the pits at Norwalk was that the 179 mph speeds were bogus because the nose of the car tripped the speed clock, not the front wheels.
Almost everything nowadays trips with the nose, pro stock, factory showdown, super classes, etc. Stock/Super Stock will if you brake at the right time. Ever look at the Funny Cars when they show the slo-mo down track? The bodies actually scrape the ground. Finish line beams are higher than start line beams.
Phil Molski
PMR Performance
S/C 1623
Old 06-24-2019, 09:35 PM   #15
Carguy49
Liked 2,974 Times in 716 Posts
Thanks for the added info. I wasn't trying to imply anything, but as we all get older health is of prime concern. Things can change quickly as you age. I believe Don is in his eighties, if wrong I'm sorry.
Also, Don is a very busy guy. I loved seeing some his cars at auction recently.
Ron McDowell - Did Race
Old 06-25-2019, 07:03 AM   #16
Superfan1
Superfan1's Avatar
Smile Re: Factory Stock Showdown - Norwalk
Don is in his eighties. I'm 72 and I hope that I am as active as Don when I reach his age.
Bridgeport, CT
Old 06-25-2019, 07:39 AM   #17
Ralph A Powell
Liked 225 Times in 136 Posts
The Have's are widing the gap from the have not's! Unless NHRA can figure out how to pull in the reins which I don't believe they have the technologies to police this!
Old 06-25-2019, 08:13 AM   #18
Billy Nees
This was supposed to be funny right?
Billy Nees 1188 STK, SS
Old 06-25-2019, 04:30 PM   #19
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
This is true; the bogus speed would only occur if the speed trap was tripped with the wheel and the finish line was tripped with the nose.
At those speeds, a difference of about 21.5" would change the reading 5 mph if I'm doing my math correctly.
S/ST 51
S/C 53
Old 06-25-2019, 04:39 PM   #20
Frank Castros
Liked 2,749 Times in 971 Posts
FSS has become what Pro Stock was in 1975.
