Old 06-22-2019, 11:33 PM   #1291
Rod Greene
Liked 242 Times in 81 Posts
Default Re: H-I-J '76 Nova re-fit.
So you are mounting the race pak sensor for the trans through the fill hole?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 06-23-2019, 05:22 PM   #1292
Nmbr1GMfan
No, I'm going to drill and tap the case under the fill plug to line up with the counter shaft.
Todd Greene
Old 06-23-2019, 05:31 PM   #1293
Nmbr1GMfan
Tapped holes for all the pipe plugs today and did some more grinding and chamfering on the block.
Todd Greene
Old 06-24-2019, 04:45 PM   #1294
Nmbr1GMfan
Not much done today, only the lifter bores grooved.
Todd Greene
Old 06-24-2019, 06:36 PM   #1295
Billy Nees
Liked 7,790 Times in 1,744 Posts
Why????????????????????????????
Billy Nees 1188 STK, SS
Billy Nees is online now   Reply With Quote
Old 06-24-2019, 07:17 PM   #1296
HP HUNTER
Liked 373 Times in 129 Posts
LOL ahhhhhhhh
I can only say we go to great lengths to control oil leaks in the engine, and 16 lifter bores is definitely one of the places were looking to control.
Old 06-24-2019, 08:25 PM   #1297
Nmbr1GMfan
Because I don't think the cam will live with 400+lb of spring pressure and no help.
Todd Greene
Old 06-24-2019, 08:48 PM   #1298
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I’m glad I was not the first one to say WHY ?
Geez.
I built a low buck 350 for my buddy when he first started racing.
Cast HyperE pistons, cast crank, stock rods, flat tappet cam with .012” EDM’d lifters
Cam had .500+ lift I’m sure and 400lbs open pressure or dang near it.
It lived for years and went 10’s in a 2800-2900 lb Camaro running brackets and S/ST and the engine got sold running minus top end ....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 06-24-2019, 09:15 PM   #1299
Nmbr1GMfan
Geez.
This makes no sense to me. You did the same thing only with the EDM lifter.
Todd Greene
Old 06-25-2019, 06:36 AM   #1300
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
What size are those grooves? Lifters have edm holes? Didn't you have an oiling problem already?
