Old 06-17-2019, 05:31 PM   #1
GrapeApe7575
GrapeApe7575's Avatar
Liked 341 Times in 77 Posts
Default National Event Credentials
Is anyone else having difficulty printing National Event driver credentials? I followed the process through NHRARACER.com and it tells me my membership# has already been used. Not sure what that means but I still have no credentials in my hand.
Has anybody solved this problem?
GrapeApe7575 is offline   Reply With Quote
Old 06-20-2019, 10:06 PM   #2
mopargilley
Liked 5 Times in 3 Posts
Default Re: National Event Credentials
Find the E-mail NHRA sent you and follow the directions.
mopargilley is offline   Reply With Quote
Old 06-21-2019, 01:06 AM   #3
Chuck Stubeck
Liked 83 Times in 20 Posts
Mark, I printed out my Sonoma Driver's credential and it gave me a Crew pass without any restricted area pass. I've had NHRA and the ticket company working on the issue for a week now.I printed my wifef's crew credential and had no issues. They can't figure it out. All I need is to have it re printed correctly. No luck so far. Chuck
Chuck Stubeck is offline   Reply With Quote
Old 06-21-2019, 01:08 AM   #4
Chuck Stubeck
Mark, call me tomorrow and I'll give you some insight. Chuck
Old 06-24-2019, 10:25 AM   #5
GrapeApe7575
Going on two weeks now with no results. And yes, Larry I did follow the instructions but it still failed. What a pain!
Old 06-24-2019, 11:29 AM   #6
Casey Miles
Liked 508 Times in 92 Posts
Do yourself a favor and print out your tech cards, once you set it up, you can print them as many times as you want, it makes it very easy to just sign and hand it in.
Casey Miles
Stock
Old 06-24-2019, 04:21 PM   #7
pentastarrail
Liked 14 Times in 5 Posts
If someone figures out how to print DRIVER Credentials PLEASE Enlighten us.
crew came out fine.
It states that I have none.
WTF
Alias:
BIG KAHUNA
pentastarrail is offline   Reply With Quote
Old 06-24-2019, 05:08 PM   #8
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
You will go to http://www.nhraracer.com/content/gen...256&zoneid=175 and enter in your member number and national event registration password. That is the same password you used when you registered for the event.
I copy and pasted this from an email I received from NHRA. It worked for me for the Norwalk National.
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
Old 06-25-2019, 06:34 AM   #9
pentastarrail
After several attempts (with a couple hours in between) I was able to get my credentials.
Thanks to all.
Frank
Alias:
BIG KAHUNA
Old 06-25-2019, 01:58 PM   #10
DG7050
Liked 115 Times in 31 Posts
Sonoma will be my first National event after a 15 year absence. Things have change a lot. How many credentials am I supposed to get with my entry?
DG7050 is offline   Reply With Quote
