Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 06-10-2019, 09:19 PM   #1
R5ROB
R5ROB's Avatar
Default Re: Late Challenger Smart Door Glass Controllers
I just went thru this on my drag pak with 16 volt battery
I thought my controllers was burnt up from the hi voltage and purchased new modules
Come to find out the controllers in my car where good and just didn’t like the high voltage
Friend at golf cart shop got me a voltage step down that they use on the carts to install radios n lights
For 15 bucks the voltage step down box worked
Bob
R5ROB is offline   Reply With Quote
Old 06-11-2019, 05:47 PM   #2
Stick cars rule
Stick cars rule's Avatar
I tried a few different things.most did not reduce voltage to where the controller was happy.ended up with a reducer from red hawk #volt0009.works good with car running,not so much when its not.the only thing good about these door glass controllers is they tell you when your battery is low.
Scott justo.
2009018 lc22r
Stick cars rule is offline   Reply With Quote
Old 08-16-2019, 12:13 AM   #3
GTS340
Liked 1,309 Times in 398 Posts
Well some of my questions were answered. I just started building a 2009 Challenger for stock this last couple weeks. Took that long to strip a real street car. One old guy anyway. The windows are a problem. I'm reading here that the Drag pak Door Modules are not available anymore. I'm not that sharp on what it takes to wire it. I've stripped the interior and removed the dash assembly to get ready for a roll cage. Amazingly enough though the wiring is out of the car from the dash forward. The mirrors still operate and the doors lock. Have no clue how to fix the windows yet. Any help would be great.
Paul Haszlauer
Old 08-16-2019, 12:58 PM   #4
DonatoEng
Liked 8 Times in 5 Posts
Paul,
I can help you out on the wiring and some other unique Drag Pak components. PM me when you have time.
John
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 08-16-2019, 03:34 PM   #5
GTS340
Thanks John,
Hopefully I sent you the P.M. correctly
Old 08-20-2019, 07:00 AM   #6
Liked 10,655 Times in 2,211 Posts
John helped me fix mine. Thanks again John!
Old 08-21-2019, 05:38 PM   #7
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
John is the man on the DP Challenger.....
Mack Reeves
2377 STOCK & SUPER STOCK
