#1241 |
Liked 73 Times in 36 Posts
Although not a bubble-pack solution, one can enhance the strength of the bottom end of a two-bolt block with a little thought and inexpensive parts.Using 7/8" keystock and milling the caps so they are flat on top......The pic speaks for this simple solution. Stronger than after market 2 bolt caps. Either method requires checking and align honing. Thus far the pic represents approx $30 spent for all the caps 1-4 and keystock. Not align honed yet.
I encourage cost effective and logical alternatives. Sorry for the hijack..... ![]() Regards, HB2 Dissident ![]() Last edited by Dissident; 06-05-2019 at 06:10 PM. Reason: insert words |
#1242 |
I don't really have any money in it, maybe a few hundred dollars. There's no way I'm the only guy that's running a stock block. Especially since I had a two bolt with stock main cap bolts to begin with.
Todd Greene |
#1243 |
Liked 482 Times in 159 Posts
Agree 100 %, you're having terrible luck putting together one of the greatest readily available V8 engines ever designed. An aftermarket block at this level while desirable is not necessary. How many hundreds of Stock/Superstockers have belted out thousands of stout runs before there were aftermarket blocks.Yes many of the OE blocks are getting old but many are still available that have sat idle under a work bench or on a rack in a machine shop somewhere. It is great of you to share your journey with us and equally nice that so many have chimed in with suggestions. I just feel that sometimes we tend to hit the overkill button. No offence but you are building a Stocker SB not a 11000 rpm Comp engine. We are all hoping you turn the page on this horrible luck and I wouldn't have the courage to post publicly like you have done. Hats off to you,Todd and Amber.
#1244 |
Tim, I built this in the late 80's, it was my street car. DOT M&H's and mufflers 3700lbs 383 with a stock non filled 2 bolt block it would run high 9's@140+ and I beat it weekly with that stock block.
Todd Greene |
#1245 |
Liked 974 Times in 310 Posts
Ring seal is extremely important in a stocker or for anything that you want to make as much power as possible. How much will you spend prepping the oem block
#1246 |
I have to buy main studs and hard block, I'm also paying to try this rust stripping deal, so probably $300.
Todd Greene |
#1247 |
Liked 312 Times in 175 Posts
Using an OEM block is fine, just not optimum. My point was not to waste your money on aftermarket main caps and the labor to install them.
#1248 |
Once I get to the point of machining, if the caps are an issue they'll be replaced but I don't expect to.
Todd Greene |
#1249 |
Liked 355 Times in 136 Posts
Uh, please pardon the off-top question, but PLEEAAZZE tell us that you still have that '57 2-door long top in your garage!
#1250 | |
Todd Greene Last edited by Nmbr1GMfan; 06-06-2019 at 12:00 PM. |
