Old 06-02-2019, 11:31 AM   #1
Rory McNeil
Liked 1,104 Times in 302 Posts
Default MoPar stickshift parts
Quick Time scattershield for SB MoPar. SFI version with window for easy counterweight adjustment. comes with block plate. SFI sticker expired. $400.00
MoPar input shaft for G Force G101A 4 speed transmission. 1 3/16"x18 "Hemi" spline. $250.00
MoPar front bearing retainer for G101A trans. $90.00
Also have a Long shifter mounting plate only for Long Pistol Grip V Gate shifter for G101A 4 speed. standard location (20 1/2" from front of case). $30.00
Homemade shifter mounting plate for Long Pistol Grip V Gate shifter, with shifter rods. (no Heim rod ends, just the tubes). Locates shifter 26" from front of case, This bracket locates the shifter about 2 inches higher than standard position, so reverse lever on trans points up, rather than down. $60.00.
NHRA 6390 STK
M/S 85 Mustang
