Old 04-18-2019, 11:53 AM   #1
340Cuda
Liked 805 Times in 341 Posts
Default Dana 60 lube
How much gear oil are you all running in your Dana 60s?
I think stock capacity is 2.75 quarts. I have been running two quarts and have been wondering if others have had good luck with less.
I am not talking about one heads up run but for the whole season.
Thanks,
Bill Lamb
Old 04-18-2019, 12:14 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
Default Re: Dana 60 lube
I run 2 qts of synthetic in my Dana. I have also tried 1 qt with no difference in performance.
Mike Pearson 2485 SS
Old 04-19-2019, 10:46 AM   #3
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I agree with Mike, 2 qts. of synthetic gear oil. The AMX had a lot of runs on the previous gear set, with Royal Purple gear oil in it. The gears came out looking perfect, and are in the trailer as a spare set.
Patric Fox is offline   Reply With Quote
Old 04-20-2019, 10:07 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I've safely run 1 1/2 qts for years in my Javelin and the Willys with Dana 60's .
I've used 75w/140 synthetics in them with no gear or bearing wear over thousands of runs over the years..
Any brand with similar viscosity ratings and GL5 rating should perform the same.
Tom Goldman is online now   Reply With Quote
