Liked 359 Times in 103 Posts
Liked 89 Times in 28 Posts
Sounds good Rick! Thank you and see you there.
Liked 320 Times in 102 Posts
HI,
Are the regulators deadhead or return type???? If they are return type, what are the part numbers??? Thanx, Bob
#4 | |
The Pro Flow has 2 inlets and 4 outlets. Not sure of its model it has only a serial number of 2486 on its tag. I used this one back in the early 1990's and carried it since then. The Aeromotive is a model 13201 with 1 inlet and 2 outlets all 6an I used this one until recently when I went to a Quickfuel pump and regulator system. The Holley is an old blue model 34R-6657B 1 inlet and 2 outlets. I used it with 2 holley blue pumps also back in the 1990's. If you are interested just stop by in Vegas and take a look. I will be parked near the Pro Stock area in a White Renegade Motorhome and White Renegade Stacker Trailer with all the other white trailers. Both will have Texas tags so there should not be many of those in the area with all the other White Trailers. I will be close to our friend who has a black trailer with a big orange skull on fire on the back of the trailer. It belongs to Jeff Connelly who runs both Top Sportsman and Top Dragster. Just stop by. Thanks Rick Cates Canyon, TX |
Thanks..
